millertime23
Aug 24, 2021Aspirant
Can no longer VPN into port 443 on R7000
I had TCP port 443 configured for the openvpn settings on my R7000 router and it was working perfectly. After the firmware upgrade to v1.0.11.126_10.2.112 my VPN will no longer connect. I tried...
LionBS
Nov 02, 2021Aspirant
Hello.
I have the same problem but with model R6700v3 and software version (V1.0.4.118_10.0.90 and V1.0.4.120_10.0.91).
Can't use VPN TUN TCP ort 443 anymore.
If it's a new software design restriction NetGear should communicate with their customers.
