khapunkap
Jun 28, 2022Follower
Can not access NETGEAR router login
Hope you can help. Specs - Modem: Arris DG3450 (also a router) Router: NETGEAR Nighthawk R7000 Firmware: unsure but definitely outdated since 2017 WiFi extender: NETGEAR Nighthawk EX7000 Internet pr...
microchip8
Jun 28, 2022Master
routerlogin only works when the router is the only one on the network. You have 2 routers (your Arris + the R7000). In that case, look up the IP Address of the R7000 assigned by the Arris and use it to login (eg, http://192.168.0.10)
