dayleen
Jul 05, 2021Follower
Can not activate subscrition code
Hello,
I am facing issue to activate my subscription.
After pay, i have got a code actication, but this code does not work.
I have this message : "This key was already used to generate a subscription."
Can you help me please ?
Davy-Steeve
this is the community support forum. where members of the public help out. You'd want to either contact netgear support or bitdefender's support.
https://www.netgear.com/support/product/netgear-armor.aspx
https://www.bitdefender.com/site/view/netgear.html
What for? Circle? Armor? Something else?
Armor has its own bolt hole:
NETGEAR Armor - NETGEAR Communities
Circle is here:
Circle Smart Parental Controls - NETGEAR Communities
