Leodee
Dec 03, 2021Aspirant
Can not connect to MyQ
Background: I moved in a new house with a brand new MyQ garage door opener. I set up my internet with SuddenLink and connected MyQ to the Suddenlink wi/fi router. Everything worked perfectly. I ...
Dec 03, 2021Guru - Experienced User
What is the product and model# of your NG router? AC1900 isn't a model#.
Did you set up the same SSID name and PW on the NG product as used on the other router?
Leodee
Sorry, the model is C7000-1AZNAS|Nighthawk AC 1900 WiFi Cable Modem Router. On the box it says C7000-100NAS.
No I did not change anything and at this point do not know what the SSID I was using. I set up all my other devices using the Netgear info.
