eusdins's avatar
eusdins
can not login disney+ with nighthawk r7960p
hi, i have att bgw320 gateway service as modem, r7960p as ip passthru router. It works for few years with disney+, then it stops working for a month now. It is connected to r7960p wifi. Other services work fine like netflix, video prime, discover+, but not disney+. if i use bgw320 wifi, then it works fine with other streaming services. I tried to  reinstall disney app on firestick, smart tv, it is still failed with login error. Even i login disney on website via r7960p wifi, it is failed too. I did not change anything in this r7960p for last 4 years. Please let me know any solution for this problem. Thanks
  • plemans's avatar
    Try a different DNS Server. Here's a few. Also remember to change the ipv6 dns server if ipv6 is enabled.
    CloudFlare
    IPv4: 1.1.1.1 and 1.0.0.1
    IPv6: 2606:4700:4700:0:0:0:0:1111 and 2606:4700:4700:0:0:0:0:1001
    GoogleDNS
    IPv4: 8.8.8.8 and 8.8.4.4
    IPv6: 2001:4860:4860:0:0:0:0:8888 and 2001:4860:4860:0:0:0:0:8844
    • eusdins's avatar
      eusdins
      Thanks for reply, i just want to make sure before i crew it up. So i go to my ip passthru r7960p router to set dns server as you give it to me, then every devices connect to this router can login disney plus, right?
  • FURRYe38's avatar
    Any progress on this?
    • eusdins's avatar
      eusdins
      no, it did not work, just something wrong between netgear r7960p and disney plus server. Now I just watch disney plus using att gateway, it works fine, just no DLNA. Thanks.
      • FURRYe38's avatar
        Have you tried the R7960P with the ISP gateway using it's DMZ or IP-passthru for the router while it's in router mode?
        Or configure the R7960P for AP mode.
