kityowah
Sep 07, 2016Aspirant
Can not login to netgear R7000 router after factory reset
Can not login to netgear R7000 router after factory reset. All I get is connecting and after 10 minute I hit cancel and it goes to Router Password Recovery. I put in serial # of router and the ...
Retired_Member
Sep 09, 2016Borrow a laptop from a friend and see what happens. Just to be clear the password recovery is still popping up?
Some anti virus software has blocked the sign in pop-up before and had to be deleted and reinstalled.This is the first time I've heard of the the PW recovery showing up after a Factory Default reset.
Try default once again and power cycle after default reboots...still bad contact support or try the 30 30 30 reset or use a hammer on it.
Good Luck with it!
