Bredtwest
Oct 24, 2016Follower
Can not open certain ports on NightHawk R7000
I am trying to open some ports on my NightHawk R7000 router to access IP cameras that are within my LAN from the outside (WAN). After I open the ports in the Port Forwarding page of the router's web...
- Oct 26, 2016
Hi Bredtwest,
Connect your device directly to the modem and check the status of the ports. If failed, you should contact ISP to check if ports are blocked.
JamesGL
Community Team
JamesGL
Oct 26, 2016NETGEAR Employee Retired
Hi Bredtwest,
JamesGL
Community Team
