Bredtwest
Oct 24, 2016Follower
Can not open certain ports on NightHawk R7000
I am trying to open some ports on my NightHawk R7000 router to access IP cameras that are within my LAN from the outside (WAN). After I open the ports in the Port Forwarding page of the router's web...
- Oct 26, 2016
Hi Bredtwest,
Connect your device directly to the modem and check the status of the ports. If failed, you should contact ISP to check if ports are blocked.
JamesGL
Community Team
JamesGL
Oct 30, 2016NETGEAR Employee Retired
Hi Bredtwest,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
