duckman963
Jun 26, 2017Aspirant
Can someone tell me why my Nighthawk x10 is making up false dos attacks?
I know for a fact that ubisoft isnt attacking me, I also know that Facebook isnt either.
- Jun 27, 2017
It is just Netgear's wonky logging of "attacks".
People often turn up here thinking that they are under attack. Unlike you they don't check who is attacking them. So they are surprised when someone points out that it is Google, Facebook or some other innocent party.
Think of it as a "feature".
duckman963
ARRIS
model: dg1670A
provider: spectrum
The router also causes problems when I stream to certain devices, my ps4 and my smart tv.
Jun 26, 2017Guru - Experienced User
You need to bridge this ISP Modem as it's got a built in router already:
http://www.arris.com/products/touchstone-data-gateway-dg1670/
If the ISP modem can't be bridged, try using the DMZ on the modem for the NG x10 router.
- duckman963Jun 26, 2017Aspirant
Sorry, I should have said this earlier. My modem has the router disabled. So it is working purely as a modem.
