compwolf
Apr 11, 2017Aspirant
Can the Nighthawk X6 r7900 be configured to VPN and route traffic to another network over the WAN?
I know you can VPN into the local network through the router. But can the Nighthawk X6 r7900 be configured to VPN and route traffic to another network over the WAN? Thanks, Lee
- Apr 16, 2017
Hi compwolf,
Yes that is correct. The router can be VPN passthrough but not as a client. You may need to have client software on your devices connected to the router.
JamesGL
Apr 13, 2017NETGEAR Employee Retired
Hi compwolf,
The devices can be configured as VPN server but connect be use as a VPN client.
JamesGL
Apr 16, 2017NETGEAR Employee Retired
Hi compwolf,
- JamesGLApr 23, 2017NETGEAR Employee Retired
Hi compwolf,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- compwolfApr 28, 2017Aspirant
Since I cannot use a VPN client to connect into my router, I'll need to get rid of the Nighthawk X6 r7900. I have heard that the r8000 does do VPN client outbound. Is that true? It might be a viable replacement
- JamesGLMay 03, 2017NETGEAR Employee Retired
Hi compwolf,
All NETGEAR routers are VPN passthrough but not client. Nighthawk routers like R8000 can be VPN server via the OpenVPN feature but not as a client.
