Rhinorider
Feb 26, 2022Aspirant
can this router handle it and put out that fibre speed
I have upgraded to fiber @ 300gb/s. Can this router put that much out? I have sen netgear 5 and 6 , my box and info does not tell me anything
Feb 26, 2022Guru - Experienced User
What router model do you have? R####, RAX####? Orbi RBK?
Rhinorider
FURRYe38 wrote:What router model do you have? R####, RAX####? Orbi RBK?
The model is an Actiontec 1565 2.4g mine is NG R7200
- microchip8Feb 27, 2022Master
300 gb/s??? Do you mean 300 Mbps? if so, this router model shouldn't have problems to reach it
- FURRYe38Feb 27, 2022Guru - Experienced User
FYI about modems with built in routers and wifif, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/24104/How-do-I-change-my-Nighthawk-router-to-AP-mode-after-I-ve-already-run-setup
