Scottie01
Mar 19, 2021Guide
Can you "daisy chain" multiple EX7700s in Access Point mode using Ethernet connections
I have a large house (listed building) over 4 floors with very thick walls and doors. I have BT broadband via a BT Hub 2. I have successfully connected 1 EX7700 via ethernet to the BT Hub with the ...
Mar 19, 2021Guru - Experienced User
Yes you can do that and if they're all hardwired together it shouldn't impact performance.
The only other alternative I'd recommend would be looking at a mesh system like orbi or the nighthawk mesh.
Reason why is they support the seamless roaming option.
when the EX7700's are ran in access point mode, they don't function with the "onessid" function. (unless something has changed recently).
Scottie01
Mar 19, 2021Guide
Thanks for your response. I will connect up a second EX7700 and check the query you raised about the single SSID.
