artderry
Mar 28, 2021Follower
Can you disable the 5GHz on your AXC2300 dual band router
Can I disable the 5GHz band on my AC2300
Mar 28, 2021Guru - Experienced User
what actual router do you have?
AC2300 is a speed, not a model.
If you go to netgear.com/support/ type in your model number.
It'll take you to a manual that goes over disabling 5ghz (if your model supports that)
