enuru99
Apr 03, 2022Follower
Can you use the Netgear Nighthawk as a separate range extender?
Hi, I recently snagged a Netgear nighthawk to replace the Linksys Node that I have been using as a Wi-Fi extender. Since the Nighthawk is primarily a router, is it possible to use it as an extender t...
Apr 03, 2022Guru - Experienced User
What netgear router do you have?
A couple older versions had extender mode but nothing recent.
