Pakman3590's avatar
Pakman3590
Cannot access admin login page
I am unable to access the admin login page via gateway IP or routerlogin.net/.com. I am connected through Ethernet and whenever I try to access the admin login page to change router settings, it give ...
  • antinode's avatar
    Dec 20, 2017
    > [...] I have tried factory resetting the router several times with no
    > luck. [...]
       Following the instructions in the User Manual?
    > [...] even after the factory reset, the gateway IP is 192.169.1.1
    > instead of the default 192.168.1.1.
       Try the reset and reconfiguration with nothing connected to the
    router's WAN/Internet port.  A proper "factory" reset should restore the
    expected default LAN IP address, but if the WAN/Internet port is
    connected to something on the same subnet, then many things are
    possible.  (But I still wouldn't expect "192.169.x.y".)
       I'd also forget the Genie app, and stick to the (simple) web-browser
    interface with a wired connection.
       What are you connecting to the router?  Some Windows system?
    Something else?
