Mark_Oliver
Sep 24, 2016Guide
Cannot access cable modem’s Configuration Manager via R7000
My router is a Nighthawk R7000 with 1.0.7.2_1.1.93 firmware. I am attempting to replace a DSL gateway with a Zoom 5370 cable modem [just plain vanilla: no router included]. When the 5370 is direc...
- Sep 27, 2016
I'm still hoping that OP will try disabling PPPoE.
Mark_Oliver
Sep 24, 2016Guide
Thanks for the report. That gives me some hope.
I’m using the R7000 itself as the DHCP server (as configured under Advanced > Setup > LAN Setup). If I didn’t do that, I expect I’d have to manually assign IP addresses (“address reservation”) for each device’s MAC address.
The address range is 192.168.1.4 thru 192.168.1.254, so there isn’t any apparent DHCP conflict with the cable modem’s IP.
IrvSp
Sep 25, 2016Master
Opps, I meant DNS, not DHCP, sorry.
Under BASIC => INTERNET SETUP:
| Domain Name Server (DNS) Address |
| Get Automatically from ISP |
Is this selected?
Can you PING it? This is what I get:
C:\>ping 192.168.100.1
Pinging 192.168.100.1 with 32 bytes of data
Reply from 192.168.100.1: bytes=32 time=9ms TTL=63
Reply from 192.168.100.1: bytes=32 time<1ms TTL=63
Ping statistics for 192.168.100.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 9ms, Average = 2ms
Cable modem is on a different sub-net, you'll never get a conflict. 192,168,1,xxx vs. 192,168.100.xxx.
