Dror
Jan 08, 2021Follower
cannot access network hard drive
Hello I am trying to connect a Seagate Backup Plus Hub to my Nighthawk X6 AC3200 Tri-Band WiFi Router Model R8000. OS: Windows 10 Hard drive is connected directly to the Netgear router using the ...
michaelkenward
Jan 09, 2021Guru - Experienced User
Dror wrote:
Hello
And the size of that Seagate is? Netgear's ReadyShare support for USB drives is limited.
This list will give you some clues, although it is far from comprehensive:
ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
I have seen rare reports of drives as big as 6 TB, but 4 TB seems to be the limit. Anything that requires fancy drivers, exotic formatting or supporting software is not going to work on what us essentially a very basic alternative to proper Ethernet NAS.
You have posted your message in the section of this community given over to Home WiFi Adapters. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Nighthawk WiFi Routers
I will ask the Netgear moderator to move your message.
- BillstewFeb 01, 2021Aspirant
Same Issue Cannot even browse the router, shows up in my network nighborhood as the name I assigned it and it says unaccessable. It worked a while and quit. I can access the drive through web on port 80 but the computer will not map no matter what I do, I ran troubleshooter through a differnt PC and it says connection is refused by the Router itself. I have tried setting with and without passwords,, No Joy
