McShan
Aug 07, 2017Aspirant
cannot access router login to do update
When I go to router login, I cannot access it - Error message says I am not connected to my router's WiFi network. This makes no sense to me as I am using a hardwired PC to try to install updates. Ha...
- Oct 06, 2017
Thanks for the replies, I managed to fix the problem with my phone after a convoluted series of steps that I can't remember, then I was locked out of this community forum for some technical glitch type reason, so didn't bother to try and fix that til now, so thanks again.....
JamesGL
Aug 14, 2017NETGEAR Employee Retired
Hi McShan,
Access the router via the IP address(192.168.1.1).
