JoanneJ
Feb 17, 2019Aspirant
Cannot access routerlogin.net, have tried everything I know
I've been trying for a few months now to fix my Double NAT type on my Xbox, which requires me to login to my router. I have used routerlogin.net, and I have tried resetting the password. However, pas...
- Feb 20, 2019
Expert....
I own a XBOX One S Gears Of War Edition... Does that mean I'm an expert?
JoanneJ,
Disconnect your Nighthawk's WAN (yellow port) from the Rivah connection.
Connect your PC to one of the 4 available LAN ports on the Nighthawk. Power up the router. Wait a full 2 minutes. Now use a toothpick to depress the reset button on the back of the router for 15 secs. The lights (power LED, etc) should go out briefly. Now release the button and allow the router to start. Wait a full 2 min again.
PC - Open a command prompt and type the following at the prompt> ipconfig /all
Press Enter
What is listed for
Default Gateway . . . . . . . . . : its going to be 192.168.1.1 or 192.168.0.1
Use this address in your browser to reach your router's log in page.
Next steps. Configure the router as an access point. "AP Mode" - Review your manual for this configuration.
Once set, connect the WAN port to the Rivah box. >>> You can do it. Nothing to lose trying. We're here to help.
michaelkenward
Feb 18, 2019Guru - Experienced User
Does your " tried everything I know" include all this stuff?
If you cannot login to your router | Answer | NETGEAR Support
To help to narrow this down, what firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
- JoanneJFeb 19, 2019Aspirant
I really don't know much about how the router works, or much about the subject in general. Where do I find what firmware version I'm using? I apologize for my lack of general knowledge on the subject. The extent of my knowledge when it comes to a Double NAT type is that the internet is being processed by two routers. However, we only have one router, and if there is a modem, I couldn't find it. The router is connected to a little box in the basement, but it had no markings whatsoever. I doubt this has anything to do with the problems I am having, but here is a picture of it.
- michaelkenwardFeb 19, 2019Guru - Experienced User
That answers the question. That little box almost certainly isn't also a router.
Perhaps I should have asked what sort of internet you get. Cable and DSL need modems, and these sometimes also masquerade as routers.
Optical, for example, just has a terminal of some sort.
Did your research into this issue include a local search:
Search - NETGEAR Communities – Double Nat Xbox
This shows several solved messages.
- shadowsportsFeb 19, 2019Hero
Hi JoanneJ & michaelkenward
JoanneJ,
We understand not everyone has a deep understanding of hardware, networking or routers.
Thanks for the picture you provided, it shows you have an ethernet connection in your basement. What we don't know is whats "behind it". Who installed that box? Is this box from a neighbor's connection? Who is the ISP (service provider). NBN?
If your xbox is reporting double NAT, then it would appear there is some device behind that little box performing NAT (and possibly DHCP). Do you get internet if you connect a computer to that "box"?
I have just followed the link you gave me, and am trying to follow the directions. However, number 5 says "Select Start > Run. Type cmd. Type ping 192.168.1.1.
If message "Request timed out," displays, type ping 192.168.0.1.
If the message persists, your computer is not making a connection to the router." Where do I select Start?Edit: disregard this reply, I figured it out but it did not help.
