JoanneJ's avatar
JoanneJ
Cannot access routerlogin.net, have tried everything I know
I've been trying for a few months now to fix my Double NAT type on my Xbox, which requires me to login to my router. I have used routerlogin.net, and I have tried resetting the password. However, pas...
  • shadowsports's avatar
    shadowsports
    Feb 20, 2019
    Expert....
    I own a XBOX One S Gears Of War Edition... Does that mean I'm an expert?
    JoanneJ,
    Disconnect your Nighthawk's WAN (yellow port) from the Rivah connection.
    Connect your PC to one of the 4 available LAN ports on the Nighthawk.  Power up the router.  Wait a full 2 minutes.  Now use a toothpick to depress the reset button on the back of the router for 15 secs.  The lights (power LED, etc) should go out briefly.  Now release the button and allow the router to start.  Wait a full 2 min again.
    PC - Open a command prompt and type the following at the prompt> ipconfig /all
    Press Enter
    What is listed for
    Default Gateway . . . . . . . . . : its going to be 192.168.1.1 or 192.168.0.1
    Use this address in your browser to reach your router's log in page.
    Next steps.  Configure the router as an access point.   "AP Mode"  - Review your manual for this configuration.
    Once set, connect the WAN port to the Rivah box.  >>>  You can do it.  Nothing to lose trying.  We're here to help.
