dargelas
Dec 10, 2020Aspirant
cannot access to login page 192.168.1.1
from today afternoon the network crashed and the router was nomore connected to internet.I did a factory reset.The router is connected to web;but i cannot get the acces to the login page to change se...
antinode
Dec 10, 2020Guru
> Model: R6700|Nighthawk AC1750 Smart WiFi Router
Is that accurate? Not an R6700v2 or R6700v3? Look for "Model" on
the product label. Firmware version? Connected to what?
> Under windows 10 i can see that the router adress is 192.168.1.1.
How, exactly, can you see that? While you're there, what are the
default gateway and the DNS server(s)?
That's normally caused by a DNS problem, although lame firmware can
make it harder to overcome.
You might try disconnecting the R6700[vX] WAN/Internet port from
everything, and see if that address ("192.168.1.1") works any better.
