dargelas
Dec 10, 2020Aspirant
cannot access to login page 192.168.1.1
from today afternoon the network crashed and the router was nomore connected to internet.I did a factory reset.The router is connected to web;but i cannot get the acces to the login page to change se...
Dec 10, 2020Guru - Experienced User
Whats your gateway/modem?
If you have a double nat it could cause issues.
Unhook it from your modem/gateway, reboot the mode, then try to access it
dargelas
I did all things pointed on your answer.The router page login stills no access.I can't get the login page of the router
No double nat nor stuff like that
All unpplugged and replugged
Stills same issue
- dargelasDec 10, 2020Aspirant
R6700v3 model
- michaelkenwardDec 10, 2020Guru - Experienced User
It would help to confirm that.
As plemans says, it would help if you told us what your modem/gateway is?
Did you find this in your troubleshooting?
If you cannot login to your router | Answer | NETGEAR Support
