GoldenJ
Feb 20, 2025Guide
Cannot change VPN interface name to NETGEAR-VPN
Hello, I enabled VPN on router RAX45 and installed the openVPN client and VPN configuration files on my laptop. Per instruction, I need to change the VPN interface name to NETGEAR-VPN on the network ...
- Feb 22, 2025
Update:
I resolved the issue. I changed the service type from UDP to TCP. Then everything works fine. I can access local network, internet and the router through the Netgear VPN over Spectrum. Obviously, there is some compatibility issue between Netgear VPN setting and Spectrum service.
I experienced multiple issues in the process of setting up VPN server on RAX45.
Problem 1: Cannot change VPN interface name by clicking "rename" in the popup window on the Network Connections page in Windows (Control Panel\Network and Internet\Network Connections).
Solution: Click on the name of the network interface to show up a box with editable name in it. This is similar to change file name in file explorer by clicking on the file name.
Problem 2: Cannot connect to the Netgear VPN after enabling VPN service and OpenVPN client installing and setting up.
Solution: Reboot the router after VPN setup on the router.
Problem 3: Cannot access anything with Netgear VPN over Spectrum connection (no access to local network, internet or router itself).
Solution: Change the service type from UDP to TCP in the VPN setting on the router.
I'd like to share this with the group. Hope this helps the others who might experience the similar issue to mine.
GoldenJ
Feb 21, 2025Guide
I use Windows 11. Yes, I logged in with an admin acct, windows has been updated to present. Also, I restarted the computer and exited OpenVPN completely. I also tried on a different laptop, giving me the same issue.
I eventually figured that I could change the name by clicking on the name itself. In my case, I clicked on "Local Area Connection" (associated with TAP-Windows Adaptor V9) and changed it to "NETGEAR-VPN".
But now I encountered a connection problem. During connection to the router VPN, the connecting process stuck at the step "management waiting ....". It just repeated several times and then the connecting window closed by itself. I checked the log file and saw the following lines:
WWWWW2025-02-21 09:56:11 us=218000 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2025-02-21 09:56:11 us=218000 TLS Error: TLS handshake failed
2025-02-21 09:56:11 us=218000 TCP/UDP: Closing socket
2025-02-21 09:56:11 us=218000 SIGUSR1[soft,tls-error] received, process restarting
2025-02-21 09:56:11 us=218000 MANAGEMENT: >STATE:1740149771,RECONNECTING,tls-error,,,,,
2025-02-21 09:56:11 us=218000 Restart pause, 1 second(s)
I checked connectivity and did not see the problem. I could access my router using DDNS host name. I was able to access the network using the VPN on the NAS which is connected to the same router.
My VPN settings on the router are default settings as follows:
- Enable VPN Service: checked
- TUN mode: UDP
- TUN mode Service Port: 12973
- TAP mode service type: UDP
I downloaded and copied the configuration files multiple times to the folder C:\Users\{userID}\OpenVPN\config (my openVPN configuration folder) to make sure the configuration files are current. The configuration files are:
- client1.opvn
- ca.crt
- client.crt
- client.key
I noticed there is another "TAP-Windows Adapter V9 #2" for McAfee VPN on PC's network. But I was running the McAfee VPN when connecting Netgear VPN. Could that interfere with NETGEAR-VPN?
What could be wrong leading to connection failure? What do I need to check and change?
Kitsap
Feb 21, 2025Master
Yes, any Open VPN setups I have used or been around would only allow one connection at a time.
- GoldenJFeb 21, 2025Guide
Connection still failed after I disabled TAP-Windows Adaptor V9 #2. I would like to clarify that the V9 #2 (McAfee VPN) was not connected when I tried to connect to Netgear VPN in the previous post,
- KitsapFeb 21, 2025Master
GoldenJ wrote:Connection still failed after I disabled TAP-Windows Adaptor V9 #2. I would like to clarify that the V9 #2 (McAfee VPN) was not connected when I tried to connect to Netgear VPN in the previous post,
Is there a McAfee VPN application that was running but not connected?
Are you trying to test the connection from a device that is connected to the same LAN where the router is running?
McAfee software LiveSafe was running, but McAfee VPN was off.
I actually tested VPN via my NAS. Even when McAfee VPN was running, I could still connect to NAS VPN to access my home network. McAfee VPN uses WireGuard Tunnel instead of Tap-Windows Adapter V9.
Not quite sure about your question. But I tried to connect to the same NETGEAR-VPN using another laptop. I got the same issue. Using NAS VPN or DDNS connection had no problem.
I wondered if NETGEAR-VPN was recognized in the network setting. In the config file, it did say
dev-node NETGEAR-VPN
I tested by changing the interface name backup to original name "Local Area Connection". It gave exactly the same response.
