debauchery
May 31, 2016Tutor
cannot close ports 21 and 443 on r7000 router
my nighthawk r7000 router is running firmware v1.0.6.28_1.1.83 and i am comcerned with the security of my network since ports 21 (ftp) and 443 (https) are both always opened for exploits. these resul...
- Jun 14, 2016
AWESOME! that did it!
just down graded to firmware v1.0.5.64_1.188
rebooted unit and wah-lah...port 21 (FTP) is closed to shields up port scanner.
Thanks!
TheEther
May 31, 2016Guru
Go to ADVANCED > USB Functions > ReadySHARE Storage and disable FTP and HTTPS (via Internet).
debauchery
Jun 05, 2016Tutor
port 21 is still open even after disabling ftp and https in readyshare usb functions.
- TheEtherJun 05, 2016Guru
Do you have UPnP enabled? If so, disable it. Reboot the router.
- debaucheryJun 08, 2016Tutor
UPnP is not turned on, and port 21 is still open.
will try rebooting again.
