debauchery
May 31, 2016Tutor
cannot close ports 21 and 443 on r7000 router
my nighthawk r7000 router is running firmware v1.0.6.28_1.1.83 and i am comcerned with the security of my network since ports 21 (ftp) and 443 (https) are both always opened for exploits. these resul...
- Jun 14, 2016
AWESOME! that did it!
just down graded to firmware v1.0.5.64_1.188
rebooted unit and wah-lah...port 21 (FTP) is closed to shields up port scanner.
Thanks!
debauchery
Jun 13, 2016Tutor
Is this r7000 broken? Or are all netgear router open for exploits?
- TheEtherJun 13, 2016Guru
I have not seen any one else with your problem. Can you try a different port scanner to cross check the results from gibson's research?
Last thing to try is a factory reset.
