debauchery
May 31, 2016Tutor
cannot close ports 21 and 443 on r7000 router
my nighthawk r7000 router is running firmware v1.0.6.28_1.1.83 and i am comcerned with the security of my network since ports 21 (ftp) and 443 (https) are both always opened for exploits. these resul...
- Jun 14, 2016
AWESOME! that did it!
just down graded to firmware v1.0.5.64_1.188
rebooted unit and wah-lah...port 21 (FTP) is closed to shields up port scanner.
Thanks!
debauchery
Jun 13, 2016Tutor
Is this r7000 broken? Or are all netgear router open for exploits?
TheEther
Jun 13, 2016Guru
I have not seen any one else with your problem. Can you try a different port scanner to cross check the results from gibson's research?
Last thing to try is a factory reset.
