debauchery
May 31, 2016Tutor
cannot close ports 21 and 443 on r7000 router
my nighthawk r7000 router is running firmware v1.0.6.28_1.1.83 and i am comcerned with the security of my network since ports 21 (ftp) and 443 (https) are both always opened for exploits. these resul...
- Jun 14, 2016
AWESOME! that did it!
just down graded to firmware v1.0.5.64_1.188
rebooted unit and wah-lah...port 21 (FTP) is closed to shields up port scanner.
Thanks!
TheEther
Jun 14, 2016Guru
I just noticed that you are are running v1.0.6.28_1.1.83. It's been recalled due to bugs. You should downgrade to 1.0.5.64. Get it here. It's strongly recommended for you to perform a factory reset after installation and reconfigure by hand. Do not restore from a backup file because it could be incompatible.
There are several, great 3rd party firmware options for the R7000. I use Asuswrt-Merlin.
debauchery
Jun 14, 2016Tutor
Thanks!
