Maximillion
Aug 04, 2015Aspirant
Cannot connect after newest firmware update for Microsoft Surface Pro 3
Hi, I have upgraded my Surface Pro 2 to Windows 10... had no issues connecting to R7000 on 5G band. After upgrading the R7000 firmware to the latest version (V1.0.4.30_1.1.67) I am now having issues ...
- Aug 12, 2015
Thanks a bunch, I went through all the processes of "Factory Reset" and that certainly didn't help. I took your advice and instructions on reverting back to 1.0.4.28 and it worked like a charm!
I now connect my Surface tablet automatically at a distance of 50 feet or so through 3 walls out on my deck (as far as I've ventured so far) no problemo!
With the latest firmware I had to be sitting next to the router. The latest firmware really is baaad!
Thank sagain for your help!
netwrks
Aug 04, 2015Master
Did you factory reset the R7000, after the firmware upgrade?
Maximillion
Aug 12, 2015Aspirant
No I didn't the firmware upgrade was an automated one
