Technographie
Jul 20, 2020Aspirant
Cannot connect PS4 to AX1800
I bought a RAX20 (AX1800) recently and I'm unable to connect to my PS4. It just doesn't find the PS4. All other devices are found without issues. Does anyone have any idea how to resolve this? Thanks...
- Jul 23, 2020
You can turn off AX in the wireless settings for the router.
AX is only going to change the speeds if your devices are AX. There aren't many AX devices released currently and the PS4 definitly isn't.
Jul 20, 2020Guru - Experienced User
the router doesn't find the ps4. The ps4 is what connects to the router. Did you re-run the setup process on the ps4?
