Technographie
Jul 20, 2020Aspirant
Cannot connect PS4 to AX1800
I bought a RAX20 (AX1800) recently and I'm unable to connect to my PS4. It just doesn't find the PS4. All other devices are found without issues. Does anyone have any idea how to resolve this? Thanks...
- Jul 23, 2020
You can turn off AX in the wireless settings for the router.
AX is only going to change the speeds if your devices are AX. There aren't many AX devices released currently and the PS4 definitly isn't.
Technographie
Jul 21, 2020Aspirant
I meant it the other way around. The PS4 can't find the router. It still can't. All other wifi networks are found, but not mine.
Jul 21, 2020Guru - Experienced User
try disabling the AX. Some older devices have had issues with AX.
- TechnographieJul 22, 2020Aspirant
Thank you for the response.
What do you mean by disable the AX?
Turn it off and on again? I've done that.
Interestingly, my PS4 was able to find and connect to the router for some reason yesterday, but when I went in today, I was having the same issue where the PS4 could not find or connect to the router.
- plemansJul 23, 2020Guru - Experienced User
No, just try it with the AX turned off.
- TechnographieJul 23, 2020AspirantI'm sorry I'm not very technical and I have no idea what turning off the AX means.
How do I do it? And does it mean a slower connection for my other devices?
Thanks!
