Technographie
Jul 20, 2020Aspirant
Cannot connect PS4 to AX1800
I bought a RAX20 (AX1800) recently and I'm unable to connect to my PS4. It just doesn't find the PS4. All other devices are found without issues. Does anyone have any idea how to resolve this? Thanks...
- Jul 23, 2020
You can turn off AX in the wireless settings for the router.
AX is only going to change the speeds if your devices are AX. There aren't many AX devices released currently and the PS4 definitly isn't.
MagmaDoctor
Jul 31, 2020Aspirant
Excuse me? I didn't ask for your help on any issue in my post. Nor did OP report that disabling AX helped him.
schumaku
Aug 01, 2020Guru - Experienced User
MagmaDoctor wrote:Nor did OP report that disabling AX helped him.
Who ever marked that post as a solution then - the OP or a NTGR mod/superuser.
- MagmaDoctorAug 01, 2020Aspirant
you must hae a mental illness to not understand the concept of past and present
