Aquanex2
Oct 09, 2021Aspirant
Cannot connect to Nighthawk AC1900 after setup
I was having issues with my Nighthawk, so I reset it and attempted to reconfigure it. Everything seemed fine. I was able to connect it to my Xfinity modem and I could see the SSID I set it to in my li...
michaelkenward
Oct 10, 2021Guru - Experienced User
Aquanex2 wrote:
I was having issues with my Nighthawk, so I reset it and attempted to reconfigure it. Everything seemed fine. I was able to connect it to my Xfinity modem and I could see the SSID I set it to in my list of Wi-fi networks.
What is that modem? Make and model? Any chance that it is a combined modem/router?
The EX7000 in your footer is not a router, but a wifi extender. So there must be a router of some sort in your network what is it? Is that the "modem"?
If the EX7000 is what you own, you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
