76_South311398
Jan 19, 2022Aspirant
Cannot connect to router
Did an update on NightHawk and now it won’t let me finish or connect to router. Keeps saying cannot find router to connect.
Jan 19, 2022Guru - Experienced User
What model router do you you have?
How was the FW updated on the router? Nighthawk app or Routers web page?
Try a power OFF of the router for 1 minute then back on...
- 76_South311398Jan 19, 2022AspirantI powered it off, push the reeet button. Took all wires out and put back in. Turned the power off and an. I did everything and still nothing.
- plemansJan 19, 2022Guru - Experienced User
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash- 76_South311398Jan 19, 2022AspirantI don’t have a computer or laptop to do these steps.
