Wifiext22
Dec 19, 2022Follower
Cannot connect to router
I have rebooted my router twice but it will not show up on the netgear genie app
michaelkenward
Dec 19, 2022Guru - Experienced User
And which genie app is that?
This could be one of several things, the browser interface, a Windows or Mac program for a PC, or a mobile Android/iThing app. Netgear labels them all as genies. Which are you using?
Does whatever it is support your unnamed router?
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
