JLabrador
Aug 02, 2021Follower
Cannot connect to wifi ac1200 range extender
I am remote working in a 5th wheel as we travel the country for our work. I have no router, but use this to connect and extend to a campgrouds wifi. I cannot login into mywifiext becasue it states I need to be connected to netgearext wifi, but it will not connect. Not sure how to remedy this
1 Reply
This? Your footer says you have the A6150|AC1200 Dual Band WiFi USB Mini Adapter.
That has nothing to do with range extenders.
