Niels_B
Sep 16, 2018Aspirant
Cannot connect to wired devices with wifi connected device
Dear receiver,
I seem to have an issue that I cannot connect to wired devices on the R7800 with a Wifi (2.4GHz) connected device.
When using smartphone LGG6(android 8.0.0) connected to 2.4GHz Wifi, this cannot access eg the AV-receiver which is connected wired to the network. It also cannot connect to a windows PC via Remote desktop connetion. When I connect my phone Wifi to a AP on the network, it all works fine.
Did the same test with a Wifi connected Laptop running windows 10, this seems to work just fine accessing all wired devices.
Again tried the android phone after a reset, still no connection to the wired devices.
Some details on the R7800 settings:
Firmware V1.0.2.46
ISP TELFORT:
VLAN 34-prio 1 for internet > 3 ports + wifi
VLAN 4-prio 0 for TV > 1 port
DHCP enabled
QoS disabled
Could somebody help me solving this?
After installing firmware V1.0.2.58 the problem seems solved! :)
