Digibru
Aug 08, 2017Aspirant
Cannot connect wirelessly to my Cannon MX250 with Nighthawk
I successfully connected to my wireless network with my new Nighthawk. I can print from any device on the network. I have a Cannon MX250 printer that will not connect wirless. I've attempted to conne...
- Aug 16, 2017
Turns out the printer was set for IPv4. I setup IPv6 on the printer and all good. Thanks.
michaelkenward
Aug 10, 2017Guru - Experienced User
You can get the IP address by checking with the Canon IJ Network Tool. At least, you can if it compatible. Mine is the iP7200.
Good luck, you may need it. These things can be beasts to set up.
Digibru
Aug 10, 2017Aspirant
Thanks, yeah beast is right. I have the Cannon software installed so I'll give that a shot.
- michaelkenwardAug 10, 2017Guru - Experienced User
You may find that it is the change of router that is the problem. Going from Netgear to Apple could have been equally troublesome. Even Apple to Apple.
It is down to the way that Canon does things. There have been similar issues posted here with different types of router.
- DigibruAug 16, 2017Aspirant
Thanks I figured it out. My printer was only setup for Iv4 not IPv6. That did the trick. Just one other thing. When I bought the Apple router I was using before I bought the Nighhawk it was a replacing an old netgear. The Apple nstallation couldn't have gone any smoother.
