backroadrider
Nov 08, 2016Guide
Cannot create new folder on R7800 ReadyShare using Win 10 Explorer
For some reason I am unable to create a new folder with a unique name, or rename an existing file or folder on any ReadyShare network share using windows exporer. I can copy existing files and folde...
- Mar 29, 2017
For all of you who have been waiting patiently (or otherwise), this problem has been resolved with the release of firmware V1.0.2.28!
srt4lifez
Nov 16, 2016Aspirant
I am experiencing the same exact symptoms on my R7800 with the same FW installed. Any updates / Fix for this?
- JamesGLNov 16, 2016NETGEAR Employee Retired
Hi srt4lifez,
We are currently checking on this issue. We will provide a feedback as soon as we have any updates.
JamesGL
Community Team
- dougskiDec 02, 2016Aspirant
I have the same problem with the same router and firmware. Please fix and put out new firmware because it is driving me crazy.
- dougskiDec 05, 2016Aspirant
There is a work around to the problem. Map a drive to the readyshare drive. Open a CMD window, use the "cd" to navigate to the directory where you want to create the new folder. First issuue a cd command to get to the mapped drive. Ex if you mapped the drive to Z: then type "cd z:" then use the cd command to move to the desired folder. Ex cd "my music", use double quotes if the folder name contains spaces. Use the "mkdir" command to create the folder. If the folder name contains spaces, enclose it in double quotes. ex mkdir "My new directory". I haven't tried it but the "rename" command should work as well to change the name of a folder.
