backroadrider
Nov 08, 2016Guide
Cannot create new folder on R7800 ReadyShare using Win 10 Explorer
For some reason I am unable to create a new folder with a unique name, or rename an existing file or folder on any ReadyShare network share using windows exporer. I can copy existing files and folde...
- Mar 29, 2017
For all of you who have been waiting patiently (or otherwise), this problem has been resolved with the release of firmware V1.0.2.28!
blacam00
Dec 26, 2016Initiate
Any updates on this from the netgear team?
I have a WD 2tb portable drive connect to the usb 1 and have the same issues as the original poster.
Can you please address this?
JamesGL
Dec 28, 2016NETGEAR Employee Retired
Hi blacam00,
We are still working on this. We will update you as soon as resolution is available.
JamesGL
Community Team
- n8wdavisJan 17, 2017Aspirant
JamesGL - Any updates on this? I'm experiencing the same issue. Windows 10 Pro. R7800. Western Digital My Book. Not able to name/re-name folders. Thanks,
- JamesGLJan 19, 2017NETGEAR Employee Retired
Hi All,
Still working for the resolution. Updates will be provided as soon as fix is available.
- hsessoJan 25, 2017Aspirant
JamesGL: Any resolution to this issue yet? Have the R7800 router, Win10 devices. The inability to create new folders in ReadyShare is very, very disappointing. Takes away considerable intended functionality of network connectivity. While the workarounds technically work, they are for backup purposes, rather than the maintenance of a true network drive. Thanks!
