backroadrider
Nov 08, 2016Guide
Cannot create new folder on R7800 ReadyShare using Win 10 Explorer
For some reason I am unable to create a new folder with a unique name, or rename an existing file or folder on any ReadyShare network share using windows exporer. I can copy existing files and folde...
- Mar 29, 2017
For all of you who have been waiting patiently (or otherwise), this problem has been resolved with the release of firmware V1.0.2.28!
blacam00
Dec 26, 2016Initiate
Any updates on this from the netgear team?
I have a WD 2tb portable drive connect to the usb 1 and have the same issues as the original poster.
Can you please address this?
MikeManinger
Jan 02, 2017Aspirant
I have the same setup and I am having the same problem. I just updated the firm ware thinking I could fix the issue but no luck.
