backroadrider
Nov 08, 2016Guide
Cannot create new folder on R7800 ReadyShare using Win 10 Explorer
For some reason I am unable to create a new folder with a unique name, or rename an existing file or folder on any ReadyShare network share using windows exporer. I can copy existing files and folde...
- Mar 29, 2017
For all of you who have been waiting patiently (or otherwise), this problem has been resolved with the release of firmware V1.0.2.28!
ZUnderwood
Mar 08, 2017Guide
Hi, everyone. Just wanted to let everyone know that Netgear successfully reproduced this issue and had me test out a beta patch - which worked perfectly. Kudos to them for the quick turnaround.
I'm not sure when the patch will be formally pushed out to their users, but I can attest that they are aware of the fix and that they mentioned that it would be showing in an upcoming release.
EZRider99
Mar 09, 2017Aspirant
I hope your information is correct. I bought this router specifically to use the 2 USB 3.0 ports for backups with readyshare. I am using the current firmware and try an update everyday to see if there is a new version that fixes this issue. Thank you for your input.
