scottdac
Aug 01, 2016Aspirant
cannot determine current location
The current location feature in imaps on an imac, an ipad, an ipod touch and an android smartphone (Google maps) does not work. It worked with my previous modem, an ancient linksys e1200, which I ne...
- Aug 22, 2016
After a few days the current location service started working. This is apparently the answer -- give it a few days and it will figure out where you are.
Seems like a moderator should know this already.
ElaineM
Aug 02, 2016NETGEAR Employee Retired
Hello scottdac
Welcome to the community!
What's the exact model number of your NETGEAR device?
Did you try factory reset the router?
How about doing a firmware upgrade?
- scottdacAug 22, 2016Aspirant
