scottdac's avatar
scottdac
cannot determine current location
The current location feature in imaps on an imac, an ipad, an ipod touch and an android smartphone (Google maps) does not work.  It worked with my previous modem, an ancient linksys e1200, which I ne...
  • scottdac's avatar
    scottdac
    Aug 22, 2016
    After a few days the current location service started working.  This is apparently the answer -- give it a few days and it will figure out where you are.
    Seems like a moderator should know this already.
