nighthawksucks
Mar 14, 2021Follower
Cannot disable port scan and dos protection . WHY
Nighthawk MR60 mesh system is the model, cannot even click that option on the model prompt unless its called something I am not aware of.
Under the advanced settings in the WAN setup tab the first option is a check box to disable or enable dos and port scan protection. unchecked meaning enabled checked meaning disabled. I have clicked the box to disable it 100 times and it will not check the box to disable the setting. Stays unchecked and no amount of settings I have altered allow me to click it. WHY
1 Reply
Perhaps because this isn't the right place for that device.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Orbi - NETGEAR Communities
I will ask the Netgear moderator to move your message.
