avis123
Feb 19, 2019Tutor
Cannot figure out Service type and port number to block a computer
Hi,
I have a computer to which I have given a static ip address in my NETGEAR router. This is the device I would like to schedule computer downtime.
However for Service Blocking I have the foll...
- Feb 20, 2019
Thank you antidote and shadowports. I appreciate your help. Finally I have a solution!
antinode
Feb 19, 2019Guru
> NETGEAR router. [...]
A static address is configured on the device ("a computer") itself.
If you mean that you did something under "ADVANCED > Setup > LAN Setup :
Address Reservation" on the router, then you reserved a _dynamic_
address for your "a computer".
> [...] Now for Service Type and Port I am not sure what would be the
> parameters. [...]
Do you mean ADVANCED > Security > Block Services?
What, exactly, would you like to block? Something? Everything?
> For Service there is a dropdown that I need to choose from.
"Service Type"? If you want to block some particular, popular,
single service which appears in that list, then choose it. If you want
to block more/different services, then choose "User Defined", and
specify a (user-defined) name of your choice.
> However, for port how do I find the value corresponding to the fixed
> ip address?
You don't. Address and port (service) are two separate things.
Think of a street address and an apartment number in the building at
that address.
> I would appreciate any help for resolution of this issue.
Making clear what you're trying to do would be a good way to start.
Define "computer downtime". If you want to block _all_ Internet
access, then you could define a service which includes all ports:
1:65535.
