Lgs9364
Sep 23, 2021Follower
Cannot find how to put in password
Model EX2800, I cannot get my smart tv, iPhone, or iPad, to reconize my range extender, or imput a password.
Sep 23, 2021Guru - Experienced User
What method of setup did you use? did you use WPS? The installation assistant? The app?
What router is it connected to?
What error are you getting from your devices?
