OAJ
Jul 18, 2021Aspirant
cannot find wireless repeating function in my R6350 — AC1750 Smart WiFi Router Wi-Fi 5 Dual Settings
I can't seem to find cwireless repeating function in my R6350 — AC1750 Smart WiFi Router Wi-Fi 5 Dual Settings. Its supoosed to be in Advanced->Advanced Setup as given in instructions online but it's ...
schumaku
Jul 18, 2021Guru - Experienced User
There is no Wireless Repeater functionality according to the R6350 Documentation (Data Sheet, User Manual).
This feature is a relict of the past, and often required very similar wireless hardware on both ends. What configuration do you had in mind?
OAJ
I wanted to use this as a range extender. I have a wifi router but its range is very less in my room. I wanted to extended its range using this router so I would get better signals in my room
- microchip8Jul 18, 2021Master
OAJ wrote:
I wanted to use this as a range extender. I have a wifi router but its range is very less in my room. I wanted to extended its range using this router so I would get better signals in my roomyou shouldn't be using repeaters. They cut bandwidth in half. Set your second router in access point mode
- schumakuJul 19, 2021Guru - Experienced User
microchip8 wrote:
This implies the connection from the primary router to the access point requires a network cable installation. However, this is one of the best investments ever!
