VJOGuy
Jul 18, 2021Aspirant
Cannot get in to router settings
Hello, No matter what I try, I cannot seem to get to the Admin log in screen for my Nighthwak router. Whether I use routerlogin.net (or .com), or 192.168.1.1, I am consistently taken to the Netg...
wcalifas
Jul 19, 2021Prodigy
did you try loggin in through your cell phone's browser, I've done it with my router numerous times. Just type the 192.168.1.1 when you're connected to the wifi.
VJOGuy
Jul 19, 2021Aspirant
Thanks for replying.
Yes, I did actually try this as well. It's odd...using my iPad or iPhone, I will get prompted for the Seraial Number, and then asked to enter a new password. But then it keeps me in that loop....telling me to enter the serial number, and then update my password. It will never progress past that.
Super frustrating! But I appreciate the idea! Any others are certainly welcomed!
