RobertRossman
May 13, 2021Aspirant
Cannot get past “Change Password” - Just repeats itself
Cannot get past "CHANGE PASSWORD". First connected lan port to router. Got IP Address and connected via default login.. No matter what, kept asking me to change the password. Could not get to ...
DarrenM
May 13, 2021Sr. NETGEAR Moderator
You may try to do a factory reset on the router.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
DarrenM
RobertRossman
May 14, 2021Aspirant
Factory reset does fix the issue. After logging in, there is a pop up display saying "Please change the password!" and takes me to the "Set Password" page. After changing the password, it just goes in cycles. Pop up window comes up saying "Please change the password!". The new password never takes affect as the default password never changes.
- DarrenMMay 17, 2021Sr. NETGEAR Moderator
You may want to try this to see if it will get around that pop up.
https://kb.netgear.com/978/Completely-avoiding-the-Smart-Wizard
DarrenM
