JezUK
Jun 13, 2018Tutor
Cannot get Readyshare USB to work on my PC
I've followed the instructions, and I can see the USB on the routerlogin.net pages as well as in a browser via its IP address.
But I just cannot see it in Windows 10......
Any advice plea...
- Jun 13, 2018
And the solution is.........
a. Click on Start button
b. Type \\readyshare.routerlogin.com, in the search box and hit enter.
c. This should open a window with one folder inside similar to USB storage.
d. Check to see if your documents are inside,
e. If so go back outside of the folder and right-click scroll down to map network drive.
f. A window should appear, then select a drive letter and click finish.
JezUK
Jun 13, 2018Tutor
That's what I've been trying.
I typed Run at the Start and then typed \\readyshare
I get the "Windows cannot access \\READYSHARE check the spelling of the name, otherwise there might be a problem with your network, etc etc, click Diagnose.."
Clicking Diagnose doesn't find / fix anything.
JezUK
Jun 13, 2018Tutor
Okay,
I'm getting closer to solving this.....
I found a thread on Microsoft's Answer's forum.
It was suggested to try going to;
And that should open up an Explorer Windows which it did :)
Now.... I need to know how to 'map' that drive ??
(I wouldn't want to be typing \\readyshare.routerlogin.com at the Start button every time I wanted to access it on my network (of 2 computers connected via Ethernet).
